Template - Unique VLAN but different sizes
ksumann
i'm trying to create a template which allows me to override the VLAN Settings.
Using a template with VLAN 10 use a /24 out of 10.0.0.0/ will force me that every network size is /24.
Is there another way? At different branches i have different network sizes.
I don't want to create different templates just because of the network size
Ryan_Miles
Meraki Employee All-Star
You would need different templates in this case. The template will enforce the mask size.
ksumann
Thats kinda sad. There isn't even some hack, like defining multiple vlans of different sizes and only change port assignment
Ryan_Miles
Port config is also defined at the template level
