Tempate Question
athan1234
Tempate Question
Hello
How should the templete be attached to the organization?
I try to clarify the circumstances.
I put together a template combination for a some  networks, We need to install an MX and swap out the current SW 250MS (trial license) for another SW 120 without a trial license.
Current Network
Name nekwork: Sanjorge
Device :Ms250
License :Trial
My colleagues advise me to start a new network, such as sanjorge01, as the best course of action. and attached  the template and attached the MX an MS .
Name nekwork: Sanjorge01
Device :Ms120 and MX
License :Mx , Ms120
My plan is to connect the existing San Jorge network to the templete for before I am able to attach the  anew  Mx and
 new Ms120 and erase the MS250 however my college advises against proceeding out of fear.
What is the best approach to take it ?
As I said, it won't have any impact. Trust me.
9 Replies 9
Just, create new networks, bind them on the template and test the configurations before migrating. After you confirm that it all working as expected, migrate It.
athan1234
why is better to creatte a new network and bind the template ?
Here a documentation that can help you:
https://documentation.meraki.com/General_Administration/Organizations_and_Networks/Creating_and_Dele...
https://documentation.meraki.com/General_Administration/Templates_and_Config_Sync/Managing_Multiple_...
I'd just bind the existing network to your template.
MS won't be affected, as you have to separately apply an MS template to a switch for it to have any impact.  The MXs are new, so it won't make any difference to them.
athan1234
Hi @PhilipDAth  yes it was my idea .
I notice that some networks are using MX 64, but I'm not sure how this will influence things because I can't see the model current MX in the template. I am able to  see the model of the SW trought the ports of the template. The client will switch from the existing MX 64 to MX 75.
Do you think if I  bind these  centers  with MX 64 it will be affect ?
How the template will affect to the current MX64 if the tempalte dosent know the new model is MX 75 . Do you think in these cases is better to create a new network for this purposes.?
@athan1234,
It will not affect anything if you bind on the template. I have a client with 800+ on the template and almost every week we need to bind 5+ MX on the template, so you don't need to be afraid.
athan1234
 I am aware that the sw has no impact because the current SW is 250 MS and the templete is 120. However, the model MX is not visible in the template . I'm not sure whether I understand myself, hehehe
athan1234
Ok thanks I always trust  you 👍
