Subscription for security
SimonLRA
Just browsing
Hello folks,
didn't find some usefull information on the forum. Is there a scheme or summary page, where all subscriptions are listed?
I just want to receive informations like
- security breaches
- eol hardware
- important updates
Thanks in advance and kind regards
Simon
Brash
If you open the left hand menu, you'll find all of the community pages.
A lot of what you are looking for can be found under "News & Announcements".
Security vulnerabilities are sometimes listed here (https://meraki.cisco.com/blog/cisco-meraki-customer-advisories/)  but for the most part are found with the other Cisco advisories
2 REPLIES 2
Brash
SimonLRA
Just browsing
Thanks Brash for the information. I will give it a try.
