I'm having a really hard time getting a site-to-site VPN connection to work with the Starlink CGNAT. When I first connected my MX65 to the Starlink, I wasn't aware of the Dynamic IP that Starlink provides, so I tried to set it up the same way I've setup MXs before. Now it seems like my Config page has that original IP locked in, despite being set to dynamic:
![DavisMurphy_2-1709686827576.png DavisMurphy_2-1709686827576.png](https://community.meraki.com/t5/image/serverpage/image-id/36070iD9608ECA7445A9C6/image-size/medium?v=v2&px=400)
I'm not even sure if this related to my problem, just something weird I noticed
My goal is try to get 2 Synology NAS devices to connect for replication. The source is at a site with traditional internet. The Partner (replication) is on the Starlink. Both ends are using Meraki MX. This setup has worked before (without needing NATs/Forwarding). It stopped working when I switched to Starlink ISP.
I've tried to use services like remote.it to get a "static" address for my source site to connect to, but that hasn't worked either. I've read that other people have tried to setup NATs or Port Forwarding to get around this, but they haven't included how they set this up. So I've tried to do this with the current "public IP" you see above, but I'm still unable to connect from the Partner site.
Here's the 1:1 NAT I've tried.
![DavisMurphy_3-1709687945109.png DavisMurphy_3-1709687945109.png](https://community.meraki.com/t5/image/serverpage/image-id/36071i690D2EFAC282332A/image-size/medium?v=v2&px=400)
I've tried to split the Starlink Uplink, so one side goes to my MX, and the other goes to an Asus Router with OpenVPN enabled. Then plug the Synology into the Asus with it's VPN Static IP, but the connection is super unreliable. MX and Asus both are very unhappy.
I see that some people say they had no issues with this, which is frustrating because I have countless hours in this and can't figure it out. Hope someone here has an idea. Thanks!
