Spreadsheet Containing DHCP Configurations
GFrazier
I see where you can import a CSV file in the Security & SD-WAN/DHCP settings to append or replace the DHCP configurations.
Is there a way to EXPORT the DHCP configurations to a CSV file?
Haseo_chen
I think you can try use  Network-wide\monitor\Clients
you can use download as to CSV file and filter what do you need
3 REPLIES 3
Haseo_chen
KarstenI
AutomationDude
I don't think there is a way to do this natively within Meraki, but you can write a python script with the API call shared above to get and then write that information to a CSV file. Hope this helps!
