Slowness while connecting to client vpn
Vishal07
Hi all,
Facing an internet slowness issue after connecting to client vpn, where some website wont open, some takes time to open. No issue for Lan, Wifi user.
Below is my architecture
5 Replies 5
Is your connection set to be the default gateway? If yes try disabling it.
Vishal07
That I will check and confirm, but when i do ipconfig/all default gateway shows 0.0.0.0. So I think if already been uncheck.
I'm going to assume you are using the Microsoft client VPN.  Try using my wizard to create a split VPN tunnel configuration.
https://www.ifm.net.nz/cookbooks/meraki-client-vpn.html
Specify just the internal subnets to include.  Then only that traffic will go over the VPN, and everything else will go direct out the users Internet connection.
Vishal07
I have checked your link. But the option showing in document doesn't appear in windows client vpn
Correct.  It can only be configured via Powershell - which is what the web page creates for you.
