Slow Transfer speed- Auto Site to Site VPN
Tiasan21
We have an issue transferring files from Auto-VPN Site to Site with two VMs from different sites.
Site 1- US - 1GB Circuit
Site 2- Germany  - 500 mb Circuit
  • Transfer speed between two sites through the LAN (VM to VM) is 700k per sec
  • MX firewall speed running same speed as ISP provider.
SMB & MTU & Iperf
 Iperf Test
- Iperf between MX's Meraki - Normal seep ;;; 200-500mbs
- Iperf between VM to VM from US & Germany ;;; 700KB/s - 3MB/s
SMB Protocol
- Tested Iperf with SMB2 - no change
- Tested Iperf with SFTP - no change
MTU
- No miss match MTU
- Change MTU - no change
Bring the Site to Site VPN down / up - no change.
Wireshark not showing enough date to identify the root cause.
Thank you,
6 Replies 6
RWelch
What MX firmware versions are you running?
Slow Site-to-Site VPN traffic
Tiasan21
MX95 Version MX 19.1.6
RWelch
You might consider trying New MX 19.1.7.1 other release: fixes issue with many clients to see if it improves your throughput.  I noticed an improvement on several MX75, MX95s and MX105s after upgrading to MX19.1.7.1.
BUG FIXES - LIMITED PLATFORM FIXES
  • Fixed an MX 19.1.7 regression that could result in MX75, MX85, MX95, MX105, MX250, and MX450 appliances servicing many clients to experience intermittent periods of heightened packet drops and latency. This resolves known issue MX-36338.
Tiasan21
Thank you, we will patch and see.
RaphaelL
Have you tried disabling IPS ?
Can you perform a packet capture ? Do you see fragmentation ? Retransmissions ?
Tiasan21
Yes we did - no change
