Site to Site VPN
rickibiza
Site to Site VPN
I'm setting up a site to site vpn between two networks under the same organization.
The site A has the 2 MX WANs directly connected to the 2 router meanwhile the site B has the WAN port connected to a load balancer and the load balancer is connected to the 4 routers we have.
I have this error on the site B "This WAN appliance is behind a VPN-unfriendly NAT, which can be caused by upstream load balancers or strict firewall rules."
The network configuration in the site B is : I open the ports  I need for my services on the 4 routers, the load balancer has a port forwarding for ALL  the ports (1-65535)to the MX.
I reckon there is something that the auto vpn site to site doesn't like.  Someone could help me please?
Thanks a lot!
8 Replies 8
Take a look at this discussion.
https://community.meraki.com/t5/Security-SD-WAN/NAT-Unfriendly/m-p/48968
rickibiza
I'm not sure if I get it right: if I choose one ip public I can just use one of my routers. If it fails the VPN will be down. There is no failover with this method.
GIdenJoe
Basically you need to tell the VPN registry what public IP and port will be always pointing towards your MX for this to work.  This means the MX is not able to contact the registry itself with the IP and port combinations.
In the end you need to have one UDP port configured that always goes to the MX.
rickibiza
ok thank you!
In this case I don't have any redundancy in case of problem on that public ip (router issues) and that's might be a big problem.
GIdenJoe
Indeed, if you can't share that same IP between multiple routers then your upstream redundancy is non existent.
It is better to have two upstream circuits tied to both WAN ports since you can then actually use your SD-WAN features between the sites.  Now you're stuck with a single WAN on the second site which is then load balanced upstream.
Alternatively if you would have a public subnet behind those 4 routers and have them use an FHRP like HSRP/VRRP/GLBP. You could have redundancy and no autoVPN issues.
rickibiza
Yeah, that's a shame.
Losing the redundancy the vpn is not 100%reliable.
Thanks a lot, I'll find another solution, maybe skipping the load balancer.
GreenMan
Meraki Alumni (Retired)
My question would be;   what's the driver behind wanting four links?
rickibiza
redudancy, we cannot 100% rely on the provider. Our locations are on an island and the service sometimes is not so good on high season.
