Site to Site VPN issue
Sachin
I am doing POC on MX devices to create Site to Site VPN (Hub/Spoke).
Topology :
HUB:
Huawei 4G Router ---> MX67 ---->  MS ---> Test machine
 (Public IP)             (WAN IP Private IP)
                                 192.168.1.XX through DHCP
Spoke:
                                 192.168.2.XX through DHCP
I am able to see VPN status is up & local routes are being exchanged with each other but showing in down state means unable to ping test machine from HUB to Spoke or vice versa. Even MX to MX is not pinable. I checked logs through packet capture Wan IP (192.168.1.X) is trying to communicate with other site Wan IP (192.168.2.X) & Public IP (76.XX.XX.XX) but unable to see any reverse traffic from other side. Same pattern is also seeing other HUB side. Someone please let me know how can I fixed this issue & is it possible to make Site to Site VPN with upstream 4G Router.
2 Replies 2
SoCalRacer
Check port 9350 on the 4G router and make sure that is open. Also are you able to ping MX to MX?
It is typical for 4G carriers to run the default APN through a firewall and block new inbound traffic by default.
Typically you need to change the APN to one that does not run via a firewall, or at a minimum, allows inbound traffic.
