Hi Everyone,
Hope you're all well.
I have a question regarding Public IP. On the MX450, I have an uplink on Ethernet1 having /29 subnet. Is it possible to distribute the usable IP on one of the Meraki MX interfaces (for example: ports 3-25). One of our non Meraki equipment need a to receive a public IP that is not natted.
Any recommendation on how i can do it on a Meraki MX device?
Would appreciate your advice.
Thank you.
Solved! Go to Solution.
The only way to do that would be to operate the MX in layer 2 mode - but that fundamentally changes a lot of things, so you wouldn't want to do that.
You could use a switch/VLAN on the outside of the MX, and plug your device into that (outside of the MX firewall).
Otherwise no.
Otherwise no.
