Site-to-Site VPN Hub traffic
diablo24
I have a question regarding when a Hub gets traffic destined for outside the VPN. How does that traffic leave the Hub?
Thanks in advance,
-Jerome
6 Replies 6
Can you elaborate more on your question please?
diablo24
How does the VPN get routes outside the VPN?
As @RaphaelL said that depends on your configuration. But the most common is via the default route.
RaphaelL
By leaving the hub you mean by which interface ? if so that depends on your configuration : https://documentation.meraki.com/MX/Deployment_Guides/VPN_Concentrator_Deployment_Guide
diablo24
What I'm trying to find which isn't very clear any one doc is, if a spoke wanted to leave the VPN, how does the hub get that traffic outside. (i.e. is it using the default route in the routing table? or is it using some other mechanism? WAN1/2?)
