I have a question regarding when a Hub gets traffic destined for outside the VPN. How does that traffic leave the Hub?
Thanks in advance,
-Jerome
Solved! Go to Solution.
It takes the most specific route
Or for same routes, https://documentation.meraki.com/MX/Networks_and_Routing/MX_Routing_Behavior#Route_Priority
Can you elaborate more on your question please?
How does the VPN get routes outside the VPN?
As @RaphaelL said that depends on your configuration. But the most common is via the default route.
By leaving the hub you mean by which interface ? if so that depends on your configuration : https://documentation.meraki.com/MX/Deployment_Guides/VPN_Concentrator_Deployment_Guide
What I'm trying to find which isn't very clear any one doc is, if a spoke wanted to leave the VPN, how does the hub get that traffic outside. (i.e. is it using the default route in the routing table? or is it using some other mechanism? WAN1/2?)
