Site to Site (IPSec) between Juniper SRX and Cisco Meraki
Foysol
I have configured Site to Site (IPSec) between Juniper SRX and Cisco Meraki but I'm getting below error on MX.
If anyone has experience please help. I'll appreciate if anyone can share juniper script or documents too.
Thank you very much
Foysol
Event typeDetails
Non-Meraki / Client VPN negotiation"msg: phase1 negotiation failed due to time up. d31ecfd04cf89533:9437beb688f65e4d"
Non-Meraki / Client VPN negotiation"msg: purged IPsec-SA proto_id=ESP spi=2757963834."
Non-Meraki / Client VPN negotiation"msg: IPsec-SA established: ESP/Transport 4.53.131.33[4500]->157.131.255.207[4500] spi=2466040742(0x92fccba6)"
Non-Meraki / Client VPN negotiation"msg: IPsec-SA established: ESP/Transport 4.53.131.33[4500]->157.131.255.207[4500] spi=210099101(0xc85db9d)"
Non-Meraki / Client VPN negotiation"msg: purged IPsec-SA proto_id=ESP spi=591549828."
Non-Meraki / Client VPN negotiation"msg: IPsec-SA established: ESP/Transport 4.53.131.33[4500]->157.131.255.207[4500] spi=2757963834(0xa463303a)"
Non-Meraki / Client VPN negotiation"msg: IPsec-SA established: ESP/Transport 4.53.131.33[4500]->157.131.255.207[4500] spi=146196861(0x8b6c97d)"
Non-Meraki / Client VPN negotiation"msg: purged IPsec-SA proto_id=ESP spi=3540361976."
Non-Meraki / Client VPN negotiation"msg: IPsec-SA established: ESP/Transport 4.53.131.33[4500]->157.131.255.207[4500] spi=591549828(0x23425584)"
Non-Meraki / Client VPN negotiation"msg: IPsec-SA established: ESP/Transport 4.53.131.33[4500]->157.131.255.207[4500] spi=43942668(0x29e830c)"
Non-Meraki / Client VPN negotiation"msg: purged IPsec-SA proto_id=ESP spi=251655378."
Non-Meraki / Client VPN negotiation"msg: IPsec-SA established: ESP/Transport 4.53.131.33[4500]->157.131.255.207[4500] spi=3540361976(0xd305a2f8)"
Non-Meraki / Client VPN negotiation"msg: IPsec-SA established: ESP/Transport 4.53.131.33[4500]->157.131.255.207[4500] spi=40458217(0x26957e9)"
Non-Meraki / Client VPN negotiation"msg: IPsec-SA established: ESP/Transport 4.53.131.33[4500]->157.131.255.207[4500] spi=251655378(0xefff4d2)"
Non-Meraki / Client VPN negotiation"msg: IPsec-SA established: ESP/Transport 4.53.131.33[4500]->157.131.255.207[4500] spi=15946658(0xf353a2)"
Non-Meraki / Client VPN negotiation"msg: ISAKMP-SA established 4.53.131.33[4500]-157.131.255.207[4500] spi:022e59eb33d1d55e:89198c1ec61cf838"
Non-Meraki / Client VPN negotiation"msg: invalid DH group 19."
Non-Meraki / Client VPN negotiation"msg: invalid DH group 20."
Non-Meraki / Client VPN negotiation"msg: received broken Microsoft ID: MS NT5 ISAKMPOAKLEY"
Non-Meraki / Client VPN negotiation"msg: phase1 negotiation failed due to time up. 4f567d27bb3741f9:56424bfee40a8fc1"
Non-Meraki / Client VPN negotiation"msg: phase1 negotiation failed due to time up. 42373e387081761b:22d45b89852dc39b"
Non-Meraki / Client VPN negotiation"msg: phase1 negotiation failed due to time up. 1a25c883d3c994db:7ce405740713061e"
Non-Meraki / Client VPN negotiation"msg: phase1 negotiation failed due to time up. e4c9bba582d4cdd7:0000000000000000"
Non-Meraki / Client VPN negotiation"msg: initiate new phase 1 negotiation: 4.53.131.33[500]<=>23.92.186.18[500]"
Non-Meraki / Client VPN negotiation"msg: phase1 negotiation failed due to time up. 655a6651df312eb6:0000000000000000"
Non-Meraki / Client VPN negotiation"msg: phase1 negotiation failed due to time up. 459d57ef1db9ae49:0000000000000000"
Non-Meraki / Client VPN negotiation"msg: phase1 negotiation failed due to time up. 380fcbaa302bb8dc:0000000000000000"
Inderdeep
Foysol
I checked this earlier but no luck with it. NAT-T is disabled on juniper srx but still facing same issue.
Thanks for your response @Inderdeep
AlexP
This means the MX is trying to build an IKE peering with your SRX, and not getting a response. Specifically, that string of hex values you see - before the colon - is the initiator cookie of the first message we're trying to send to the SRX, and the fact that the responder cookie is all zeroes means we didn't get any response from it at all.
