Port forwarding should work fine then in that case. The public port can be anything you choose (as long as you change your SSH command to use that port), and the local port will need to match the port used by the Aruba switch (likely TCP22):
If this is still not working, you can perform a packet capture on the internet interface to make sure the MX is seeing the incoming TCP traffic from your host. If that is seen, a packet capture on the LAN interface will help you check if the MX is forwarding that traffic internally.
If you're still having trouble, give support a call and we'll be happy to help!
https://meraki.cisco.com/meraki-support/overview/
Whilst I am a Meraki employee, some of what I post may be opinion (especially architecture!). Others may have better or more efficient ways of doing things, so please learn from everyone!
