SD-WAN over 1-armed concentrator
Nelosnc0
I have a customer that is trying to deploy SD-Wan using mpls, and DIA circuits. To do so they are using the 1-armed concentrator. Since this only has a single link how do you define the shaping rules on which vpn tunnel to send traffic over?
Adam
I think I recall someone mentioning that one of the later firmware's helps alleviate this.  But if the connection is not a true Internet/WAN connection then the traffic shaping rules won't apply.  We have this same issue at some of our sites and had to convert many of our connections to internet connections instead of private connections.
1-armed mode is really only intended for AutoVPN - and relies on something else to do the routing smarts at the DC.  You can only tell the remote branches which circuit to prefer (using SDN).  They then connect to HQ over either the MPLS or the Internet.
Personally - I would not use 1-armed mode if you want to be able to use dual uplinks at the DC/HQ.  I have avoided 1-armed mode because of this.  I would do an AutoVPN deployment over MPLS, like this:
https://documentation.meraki.com/MX-Z/Site-to-site_VPN/Configuring_Site-to-site_VPN_over_MPLS
HOWEVER - the key difference is you treat the HQ/DC the same as a branch - it is simply another node of the network.
Phil, the document you linked to also shows the 1 arm approach?
It does - which is why I put "however" in bold on the next line.  🙂
Just treat the DC/HQ as another branch, and then you get full SDN functionality with dual uplinks everywhere.
