SD-WAN & traffic shaping
alankevinr
Id like to put in a rule this weekend to allow only 20MB traffic from Azure to an On-premises  server as we are taking data off of a Server in Azure its through a VPN . Ill be using a robocopy script
I think this is the best way but id like to be sure
2 Replies 2
10.2 is azure subnet?
With 40MB you mean 20Mbps UP/ 20Mbps DOWN like in the screenshot?
Also note this is per flow that hits this rule. So more ip's / flows can together still use more than the defined limit.
Hi thank you for your reply,
Yes the 10.2.0.0/16 is a subnet in the Azure portal, we are connecting with a VPN.
I tried 40MB but the Meraki said you can only have 20MBs. I left it at 20MB.
Thank you for the advise that more IP's / flow can use the traffic shaping rule
