SD-WAN VPN
LeoAri
SD-WAN VPN
Hello
I have a question. I have 3 sites, each with an MX, with home internet connections. I want a full mesh architecture. My question is, do I need public IP addresses for all my sites? Or can it be done with normal internet services?
KH
Hey @LeoAri
Meraki AutoVPN does not require a Static Public IP if that is what you are referring to, obviously you will need a public IP on the ISP side to route out to the internet. As long as your MXes are online they can form a full mesh tunnel with each other via AutoVPN
If you found this post helpful, please give it kudos. If my answer solved your problem, click "accept as solution" so that others can benefit from it
1 Reply 1
KH
Hey @LeoAri
