- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
SD-WAN Using diffrerent Meraki Models
Hello
Has anyone set up an SD-WAN using MX100 and MX85 Appliances? I need to add a site to an existing network and the MX100 appliances are no longer available. The new MX105 devices are overkill, as the new site is significantly smaller than the other two sites.
Thank you.
Solved! Go to solution.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Do you want to add the new device for High-Availability on the network with the MX100? Then it will not work as both units have to be the same model.
But if you want to add an additional network (like a new branch office) that connects via AutoVPN, then you can take any model you want. This is quite common. For example one customer has the MX250 on the headquarter and a mix of MX67/MX68/MX84 in the branches.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Just to re-iterate what @KarstenI has said you can mix any of the MX's when implementing auto-vpn's. You can't of course mix different models for HA.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
And in case you still aren't sure, we have an 12 site solution, one site has MX250s, three have MX100s, four have MX84s, two have an MX65 and two have Z3s.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Thank you.
