SD-WAN SETUP WITH DUAL ISP
Prince
Good day!
Newbie here and I was not around during the configuration of our Meraki devices as the contractor had it preconfigured for us.
We had a total of 3 offices on which we use SD-WAN to connect from each other.  Office 1 is MX84 and Office 2 & 3 are MX64. Recently, we added secondary ISPs on all our offices. However, if the primary ISP of office 1 was down, it cannot connect to office 2 and 3, same goes with other offices.  All our primary ISPs had public IPs, however, our 2nd ISPs (Starlink) don't have since it is a residential plan and these changes from time to time.
Is there a way to connect our offices when a primary ISP went down even without those public IPs of our secondary ISP?  And what would be the configuration/setup for this.
Thanks in advance.
Prince
Hi everyone,
This was already solve on our end.  The problem was on the Starlink router and on our VLAN interface IP which were the same.  Since we cannot change the IP address of the Starlink router and it would take time and effort to change the static IPs of all devices connected to our VLAN, we added another router (configured with different IP) where the Starlink router will connect. This solves the problem we had on our network.
I appreciate all your inputs. Thanks
6 Replies 6
This is automatic, so there is a high chance that it is a problem with Starlink.
It's very simple even without a public IP.
https://documentation.meraki.com/MX/Firewall_and_Traffic_Shaping/MX_Load_Balancing_and_Flow_Preferen...
What was the specific test you performed?  Unlugging the primary ISP from the head office?
That should failover and work.  Especially if all of the sites have a public IP directly on the primary WAN interface of the MX.
Amin_Costa
There's something that might be happening. Probably the VPN between the meraki is configured as "Non-meraki VPN peers". I'm not sure but this might be the case as by default meraki use both links.
Check how the VPN is configured:
Security & SD-WAN -> Site-to-Site VPN -> Non-meraki VPN peers
Prince
Hi everyone,
CarolineS
Community Manager
Community Manager
Thank you for keeping the community updated! I’m going to mark your reply as the solution. Cheers!
