Routing traffic between OpenVPN clients and AWS S2S VPN
sparrowhawk
We have set up a S2S VPN between our local subnet on our MX100 and AWS. This is working and hosts in AWS can be reached from the LAN. We have an OpenVPN server on the local subnet but when clients are connected to this VPN, they can't reach any hosts in AWS. They can reach everything in the LAN. Can anyone point me to a guide that might help me troubleshoot why this isn't working? Thanks.
6 Replies 6
 If you’re using routing mode in OpenVPN, you might need to add a static route in your AWS VPC that points the VPN client subnet to the OpenVPN server. Also, check the source/destination checking setting on your EC2 instance.
sparrowhawk
Hi @alemabrahao thanks for your reply. We have set up a static route between AWS and the OpenVPN client IP range, and I'm told that is working. Can you expand on the source/destination checking? My dev team didn't understand that part. Thanks.
How about the security rules and ALCs on AWS?
sparrowhawk
I'll ask my devs about that. I don't have access to the AWS console, unfortunately. Do you think that traffic is not being directed back along the correct route?
We all thought that the issue is down to the MX config, but you seem to think the issue is in AWS, yes? I want to clarify if we need to shift our focus, that's all.
I would bet that the problem is on the AWS side, since in MX there are not many limitations, especially since the routes are correct according to you.
sparrowhawk
Well, the routes are correct according to my colleague who looks after the AWS side of things. I think we need to look at all angles. I was hoping there would be a guide that I could work through but I guess there are too many variables. Thanks for your help anyway, much appreciated.
