Routing help with MX100
framosCTLink
Hi Guys,
Im quite confused right now if I was able to configure everything correctly. For any routing expert out there, may I seek help please?
My issue is I want Branches A, B & C talk to Branches XYZ back-to-back thru Meraki having different network provider with different physical circuits. (please see connections below)
If this might help explain the issue much further:
Provider 1 Routing table sample is below:
192.168.100.0/24 next hop 192.168.0.246
192.168.110.0/24 next hop 192.168.0.246 and so on..
Meraki Routing table
192.168.100.0/24 next hop 192.168.100.1
192.168.110.0/24 next hop 192.168.100.1
192.168.10.0/24 next hop 192.168.0.1
192.168.20.0/24 next hop 192.168.0.1
Provider 2 Routing table
192.168.20.0/24 next hop 192.168.0.1 and so on...
after configuring allow rule on L3 Firewall on MX100, Branches ABC cant still see Branches XYZ, am I missing something?
also for the port on meraki, should I switch it to Trunk?
Franco Ramos
KarstenI
Actually, I don't really get what you are trying to achieve.
Most important is, that your MX-Ports in use are two LAN-Ports and not the WAN-Ports. For these two LAN-Ports, Access is perfectly fine.
EDIT:
You say "ABC can not see XYZ". Does this mean the other direction is working? Or in general: What is already working? ISP1 to ISP2, ISP2 to ISP1, any Branch to MX, any Branch to the other ISP?
How do you test? Are your test-packets allowed on the target-devices?
framosCTLink
Thank you for this, got totally confused yesterday and forgot to test both sides of the network, will update my post later. Thanks again!
Franco Ramos
Claes_Karlsson
To see dynamically learned routes on a router you need some kind of dynamic routing protocol. Have a look at this link to achieve dynamic learned routes from/through a MX.
https://documentation.meraki.com/MX/Site-to-site_VPN/Using_OSPF_to_Advertise_Remote_VPN_Subnets
/CK
