Routing Question
StarZen
Routing Question
We have a main location with an MX84 and 3 satellites with MX64s
We also have a VPN link to Azure using the non meraki peer
And then we use client vpn connections for laptops on the road
the issue i am having is with the routing to Azure. it works find on the main network and one of the satellites
on the other 2 satellites and on the client vpn i cant get a connection to the azure ip addresses
Main Network MX84
can ping the azure IPs from the MX UI
no problems on the network or connecting to azure
Satellite 1 MX64 uses DHCP in MX
that one works just fine. No issues at all. can connect to main network and also to azure
interestingly i cant ping azure IPs from the MX UI
Satellite 2 MX64
no DHCP used in MX (to be perfectly correct it is , has netgear orbi connected that is the gateway and dhcp for the network here.
cant ping the azure IPs from the MX UI
unable to communicate with ips on azure but no issues with talking to ips on main network
Client VPN
when connecting via client vpn i am able to communicate with main network (rdp, etc) but no communication to azure IPs
any help would be greatly appreciated.
Mike
5 Replies 5
Strange to work on one of the sites, in theory it is not possible to route a non-Meraki VPN on the SD-WAN, that is, it would be necessary to establish an Azure VPN tunnel with each MX.
Non-Meraki VPN Peers (Other IPsec)
Non-Meraki VPN peers are configured on the Security & SD-WAN > Configure > Site-to-site VPN page of Dashboard. These VPN peers are connected to using IPsec. If an MX is configured to establish a VPN with a non-Meraki VPN peer, the MX will also have routes to the private subnets defined for that VPN peer. If a full tunnel is required, both peers must configure a private subnet of 0.0.0.0/0 as its private subnet for the IPsec SAs to be created successfully.
 MX cannot route between two Non-Meraki VPN peers.
MX that builds tunnels to both Auto VPN and Non-Meraki VPN peers, will not route traffic between the non-Meraki VPN peers and other Auto VPN peers.
so yes we have site to site between main office, office 1, office 2 and office 3, a non meraki peer defined as a vpn connection to azure.
the connection to azure is working from our main office and also from office#2. it is however not working from office3 and office4 and i am not sure why one would work and not the other
and then of course there is the client vpn on the main office
Have you checked that there are no firewall rules in Azure?
This is quite a complex setup.  You could spend a lot of time on this and may never get it resolved.
Personally, I would buy a VMX-S.
https://meraki.cisco.com/product/security-sd-wan/virtual-appliances/vmx-small/
This will be tremendously simpler, and you can get it working.
