Thanks for the reply's guys,👍
Hi Philip,
the MX is running MX16.16 according to the dashboard.
Currently, i have it connected to the router via a dedicated vlan (no SVI) and a pair of access ports on a 3750 switch, just so i could do a port mirror on the traffic. I have tried it cabled directly to a layer 3 port on the router with the same results.
it works fine with OSPF disabled, drops off the network when OSPF is enabled.
I will see if i can find any release notes for 16.16 , see if there is any mention of this as a caveat.
Im having a few other oddities happening with this particular setup, I have a vMX in azure running as a Hub and two MX devices running 16.16. The vMX site to to site vPN is showing all green, the two spokes are showing disconnected from VPN registry, a packet sniff shows there are clearly talking to each other though... one for another time perhaps, but im now wondering if its got to do with the software on the MX as you suggest. hmmmm
