Hello community !!!
I have this question for you: is it possible to route ALL traffic to site-to-site VPN ?
I have an MX65W (in China) configured with site-to-site VPN (third party appliance on remote site). Is it possible to route all traffic to VPN tunnel ?
Thank you,
Luca
Security - Configure - Site to SiteVPN und tik the checkbox for "use VPN" - in the attachment I only used one vlan to be in VPN, other uses local breakout.
Should be what you want?
Hello MarcP,
I already have Use VPN tik.
I'd like to route all traffic (Internet traffic too) from LAN to site-to-site VPN tunnel (instead of Internet 1 port).
This is the objective.
If I set 0.0.0.0/0 in "Private subnets" instead of remote office IP class, will it work ?
So I imagine something like this:
What about ?
Thank you,
Luca
This is what you want then.
Just get up the Site-To-Site Tunnel and then tik the box "use VPN", so all your traffic will be routet into your Tunnel.
Tunnel will be established through Internet1/Internet2 port (depends on your cableing).
Internettraffic will be in the tunnel as well, when you set it like on the screenshot. 🙂 We have got the same setup, using 0.0.0.0/0
Hello MarcP,
but the "Use VPN" is not enough if I don't set Private subnets to include ALL subnets (0.0.0.0/0). But will it work ? I don't like to make that change and have Meraki device disconnected from cloud console (even if I don't think it will really happen).
What about ?
Bye,
Luca
correct, 0.0.0.0/0 (all) is necessary as well. It should work and your device will still be shown in the cloud, as it is a seperate connection (Meraki Managementconnection).
Hello MarcP,
good. We'll try this solution and write down feedback here (just to have a complete community post).
Thank you again,
Luca
Guys, this is very simple 😃
You have to check this box
If you uncheck the box, then the SPOKE site will use 'split-tunnel' mode.
If you check the box, then the SPOKE site will use 'full-tunnel' for any of the subnets below that say YES
Hello Nolan,
I don't have Meraki on remote site, but third party device; so I cannot select Spoke because no Hubs (from A site-to-site VPN spoke requires at least one hub to connect to - Note: Hub and spoke topologies are currently only supported between Meraki MXes, non-Meraki VPN peers cannot be configured as spokes).
Bye,
Luca
Tick the "Default Route" box to make a spoke route all traffic to the hub.
@PhilipDAth wrote:Tick the "Default Route" box to make a spoke route all traffic to the hub.
That was my assumption too @PhilipDAth but this is a setup to a 3rd party VPN, trying to do full-tunnel across that from what I read.
Hello Nolan,
interesting post. I'll look on it.
Thank you again,
Luca
