Ring Connection and Configuration on MX
Meraki1503
Dear All,
Please help me in this case.
At 'local subnet 2" have two way to " local subnet 1". In this case, I want "local subnet 2" to "local subnet 1" with MPLS primary, if MPLS is down, the second way go to fiber connected to MX (local subnet 3) connect to "local subnet 1".
All MXs are not the same Organization.
I know, MX can't create 2 route with the same destination subnet. How can I configure MX this case smooth working. Please help me.
Thanks and Best regards.
2 Replies 2
Check out this guide:
https://documentation.meraki.com/MX/Deployment_Guides/MPLS_Failover_to_Meraki_Auto_VPN
You will probably want to use route tracking to enable automatic failover to AutoVPN if MPLS goes down.
https://documentation.meraki.com/MX/Networks_and_Routing/MX_Routing_Behavior#Static_Route_Tracking
Meraki1503
Thank you PhilipDAth,
I know about your solution, but I want to backup by connected to local subnet 1 thought  from MX 2(local subnet 2) to MX 3(local subnet3)? If I can work in this case, pls help me configure on MX. I don't use VPN for backup
Best regards,
