If you are denying local lan access on the wireless firewall settings, it will block. However you are correct, for devices plugged in hardwire on that VLAN, you would want to edit the MX firewall settings to block inter-vlan communication.
For example:
You could also do some ACL on the switch side if you have SVI's on your core switch etc.
