Currently we have a DMZ configure on a Pf Sense Firewall and I'm trying to find a way to move the DMZ configurations from the Pf Sense to Meraki MX100.
Current configuration:
On the MX100 in NAT mode I don't see how to configure and get the same result as on the Pf Sense.
The way forward I think is to remove the /30 up-link to ISP subnet and configure the /28 between the ISP and the external MX WAN interface. 1:1 NAT can be use to send traffic from internet to the internal server.
Does anyone has another approach how to solve this issue.
Thank you.
Solved! Go to Solution.
That is incorrect. As long as the /28 is routed via the stub NAT will work.
The hosts in the DMZ must have private IP addresses.
Then you can configure a 1:1 NAT from the DMZ public IP address pool to the private IP address of the host in the DMZ.
https://documentation.meraki.com/MX-Z/NAT_and_Port_Forwarding/Configuring_1%3A1_NAT
Can you keep the current /30 stub network.
@PhilipDAth is correct. If the ISP route the /28 pointing to your MX, even if its a /30 network connection, it will work.
If you have one server per public IP, then you can use 1:1 NAT. If you have multiple servers sharing IP address, you can use 1:Many NAT.. This allows you to define ports to internal IP address and the internal ports as well. Just as long as the ISP route the /28 network to your MX, it will work.
