Receiving IP conflict alerts despite there not being an IP conflict. How can I dismiss this alert?
Tony69
Good morning,
I am receiving tons of IP conflict alerts for a backup repository I recently set up. I bonded the NICs and re-applied the IP, hence the IP conflict. How can I resolve this issue?
Thanks.
2 Replies 2
RWelch
There is no mention of what Meraki equipment you are using however there are a few tips below if it helps.
The MS's LACP hashing algorithm uses traffic's source/destination IP, MAC, and port to determine which bonded link to utilize.
NOTE: When configuring LACP port-channels on uplinks between remote switches/stacks, always configure the remote/downstream side of the port-channel first. Once the config has been applied configure the LACP port-channel on the upstream switch. This insures you don't strand the downstream switch.
Link Aggregation and Load Balancing
You can try to acknowledge the dashboard IP conflict alert and give it time to clear itself up.  If it persists, you might consider taking a look to verify the backup device NIC settings are configured for link aggregation.
Another option to consider would be to Release and renew IP addresses.
To resolve the conflict, you can release and renew the IP addresses of the conflicting devices. Go to the network settings on each device and release the IP address. Then, renew the IP address to get a new one.
The MX (itself) does not run LACP or any link aggregation protocols. Connecting aggregated ports to the LAN of the MX is not supported; all connected ports should be un-aggregated.
MX Layer 2 Functionality
GIdenJoe
You should investigate if multiple mac addresses are using the same IP address.  I have never found dashboard to be wrong about this.
If they see that a different mac address is using an IP address that has just been used by another mac it will throw that alert.  Maybe write the mac addresses involved down and perhaps do some pcaps to see if your device is not changing it's mac address.  You can easy apply filters on your capture to just limit between those mac addresses.
