Reach Azure over Meraki tunnel?
mmzzaq
I have 2x MX75's on different sites (SITE A and SITE B) that are connected by a site to site tunnel with method autovpn. Site A also has a working non-vMX IPSEC VPN tunnel to Azure. Anything on SITE A can currently reach VM A like it should.
Question: is it possible for DESKTOP B on SITE B to reach VM A by going over the tunnel between SITE B and SITE A and from SITE A, traverse over the IPSEC tunnel to Azure? In other words: DESKTOP B needs to reach VM A over the tunnels. I tried some experimenting with static routes but can't make it work. Maybe i'm doing something wrong.
That does not work. Every mx need a (non meraki tunnel) ipsec to azure. The only way to get this working is using the bgp over ipsec
https://documentation.meraki.com/SASE_and_SD-WAN/MX/Design_and_Configure/Configuration_Guides/Site-t...
Or meraki vmx in azure
mmzzaq
Ok thank you for the info.
