Question about MX Warm Spare setting with Three ISP its Posible?
JorgeRJimenez
Hi Team i need your help, i need to do MX84 Warm Spare but my problem begin becouse my costumer has three internet. so i need your support for this becouse i just find information about warm spare but just using two internets.
i attached some draws with my desig.
if you had some link related please share becouse its kind a hard to find something like this
Solution proposalSolution proposal
Yes that will work.  Note that ISP3 will only be usable if the primary MX has failed.
AjitKumar
Hi Jorge,
Agreed to @PhilipDAth.
I too do not see any challenges with the proposed topology.
I hope you have already referred the following Url
https://documentation.meraki.com/MX/Other_Topics/Warm_Spare
Regards,
Ajit
AjitsNW@gmail.com
www.ajit.network
JorgeRJimenez
Thanks so much, i think the point of this its becouse i missundertand the concept, Meraki Warm Spare works only with two ISP at the same time, if i want to enable more then 3 or 4 ISP we need to use MX separate and its different for Meraki warm spare concept and recomendation.
