QoS improvement request
I've been trying to work out how I can control how much bandwidth a high priority data stream (high definition video) uses over an SD-WAN site to site link.  It's perfectly easy to prioritise, but when you have 250Mbps of video trying to squeeze into a 200+30Mbps pair of connections along with all the data traffic, it just doesn't work.
On most traditional systems you can cap traffic on a certain port, of from (a) certain (range of) sources, but I cannot find a suitable equivalent in Meraki MXs.
Am I missing something, and if not, is anyone else having the same issue?
DarrenOC
Would Traffic Shaping work here Charles?
https://documentation.meraki.com/MX/Firewall_and_Traffic_Shaping/SD-WAN_and_Traffic_Shaping
create a custom rule for your video traffic - local subnet? And set a required bandwidth limit?
4 REPLIES 4
DarrenOC
Not sure how I missed that! 🤦‍♂️. Giving it a try now...
DarrenOC
We both missed it 😂🤣
Looks like setting a limit of 150Mbps worked!
Community News
