QUIC Protocol - Web filtering does not work properly from Google Chrome
Is there a best method to block QUIC or to get QUIC working with Web filters in a Meraki?
I am currently blocking by disabling the Experimental QUIC protocol on Google Chrome browsers in my environments but any non managed systems can get around this or users can simply re-enable again.
Another method is to block outbound UDP 80 and UDP 443 but not sure if this will break anything else.
Preferred solution is for Meraki web filtering or layer 7 rules to work with QUIC.
Anyone come across this issue as it is a big security hole with Chrome?
Some more details here https://itzecurity.blogspot.ie/2015/06/quic-protocol-web-filtering-not-work.html
thank you!
1 REPLY 1
Re: QUIC Protocol - Web filtering does not work properly from Google Chrome
As indicated, I would block udp/80 and udp/443.
