Public IP for Non Meraki VPN Site-to-Site Client
SOBC
The MX has a FQDN for DDNS purposes. Why wouldn't you think that a non Meraki device at the other end isn't using DDNS also? The box will only accept an IP address. It should also accept a FQDN.
BlakeRichardson
@SOBC Can you please take a screenshot of what you are trying to do, I'm a bit confused.
Greenberet
He is probably talking about this one:
On the third party VPN settings the remote destination must be an IP address. DNS names are currently not possible.
So if the remote site has a dynamic IP address, you would have to change it every time manually/via script instead of using the dns service which gets updated automatically
BlakeRichardson
@Greenberet  Ah gotcha, not sure why Meraki don't support FQDN however they must have their reasons.
Most VPN clients I have dealt with these days support FQDN so I would have thought site to site with good DDNS would be fine.
SOBC
Greenberet had the correct picture. The Cisco Small Business routers do support FQDN, so I'm surprised that Meraki doesn't.
