Hi, I've an MX 84 and it is working fine as configured. i am thinking of getting benefit of "Advanced Malware Protection (AMP)" and "Intrusion detection and prevention" features available on MX. i am thinking of getting my servers on a separate non-meraki switch, and to connect an uplink from this switch to any LAN port on the MX unit. and another uplink to the LAN non-meraki switches. will this setting trigger any intrusion attack from my LAN to the servers? Thanks
No, you wont be able to plug it in that Internet port and operate in transparent mode. Transparent mode operates between a single Internet port and the LAN ports.
Hi Philip, thanks for the reply, what about i connect the server's switch to a Internet Port, but with transparent mode. not nating mode. will this be any good. thanks
LITHIUM.InformationBox({"updateFeedbackEvent":"LITHIUM:updateAjaxFeedback","componentSelector":"#informationbox_3f63cc686c3daf","feedbackSelector":".InfoMessage"});
LITHIUM.InformationBox({"updateFeedbackEvent":"LITHIUM:updateAjaxFeedback","componentSelector":"#informationbox_3f63cc686c3daf_0","feedbackSelector":".InfoMessage"});
LITHIUM.InformationBox({"updateFeedbackEvent":"LITHIUM:updateAjaxFeedback","componentSelector":"#informationbox_3f63cc686c3daf_1","feedbackSelector":".InfoMessage"});
LITHIUM.InformationBox({"updateFeedbackEvent":"LITHIUM:updateAjaxFeedback","componentSelector":"#informationbox_3f63cc686c3daf_2","feedbackSelector":".InfoMessage"});
LITHIUM.AutoComplete({"options":{"autosuggestionAvailableInstructionText":"Auto-suggestions available. Use Up and Down arrow keys to navigate.","triggerTextLength":4,"autocompleteInstructionsSelector":"#autocompleteInstructionsText_3f63cc60ed7739","updateInputOnSelect":true,"loadingText":"Searching...","emptyText":"No Matches","successText":"Results:","defaultText":"Enter a search word","autosuggestionUnavailableInstructionText":"No suggestions available","disabled":false,"footerContent":[{"scripts":"\n\n;(function($){LITHIUM.Link=function(params){var $doc=$(document);function handler(event){var $link=$(this);var token=$link.data('lia-action-token');if($link.data('lia-ajax')!==true&&token!==undefined){if(event.isPropagationStopped()===false&&event.isImmediatePropagationStopped()===false&&event.isDefaultPrevented()===false){event.stop();var $form=$('
