Procedure authentication Client VPN with NPS/AD
MauroF
Hi all,
i configured a Client VPN linked to a Radius serve(windows server 2016)r that use a AD as a database. At the moment it doesnt work. Is there a updated procedure to follow regarding this authentication Client VPN with NPS/AD?
i checked this one : https://documentation.meraki.com/MX/Client_VPN/Configuring_RADIUS_Authentication_with_Client_VPN_IPs...  but it doesnt work.
Thanks in advanced.
m
2 Replies 2
rhbirkelund
That guide should be good enough. What is it that's not wokring? What errors are you getting?
Brash
That guide contains all of the information that should be required.
You'll need to provide some more information to pinpoint.
For example, does the client connect at all and prompt for credentials?
If so, what do you see in the event logs on the NPS? Does the request show as hitting the correct policy?
