@PhilipDAth wrote:
It is a real common problem after Windows 10 updates. @Nash loves this issue.
True that it's a common issue, untrue that I love it. I just got mad and sunk dozens of hours into fixing it.
Try the scripts in my signature.
Make sure you don't save the user credential.
Make sure you use rasphone.exe to connect to the VPN, not the network icon in your systems tray.
If you setup the VPN manually, choose "optional" Encryption. Windows doesn't support PAP with "required" and will change your password protocol.
If you try this and still have problems, give us a shout and we'll work through it with you.
