If you Z3 if default routing everything on the VPN tunnel, you're a little stuck. You'd need to reconnect your laptop/PC to your local network in order to print. I've had success with my iMac connected to both Ethernet (which goes to Z3 full tunnel) and also WiFi (local network), whereby my Mac 'knows' to send the print job to my WiFi local network.
