Search instead for
Port Forwarding and NAT on MX64
I know how this topology on a Cisco Router, can be implemented
but on a Meraki MX64, I can't figure, please show me step by step how to config this with GUI, I can't find a way in this GUI to associate one specific valid public IP address+port to a private address
Question 1)
First as you can see from the picture of MX64 itself, we have one uplink(internet link) and 4 port to internal LAN
so how can we have 2 uplinks as this menu is suggesting, I only see one port?
Question 2)
Port Forwarding
I think for this part I need to go to
Appliance status->Uplink, and click on that pen next to WAN
Switch6500(config)#int fa1/1
Switch6500(config-if)#ip add 81.1.1.30 255.255.255.252
For this part you need to goto Security -> Firewall but I can't figure how to associate public port and IP to private
Switch6500(config)#ip nat inside source static 192.168.1.50 80 81.1.1.30 80
Switch6500(config)#ip nat inside source static 192.168.1.51 80 81.1.1.31 80
Switch6500(config-if)#ip nat inside
Switch6500(config)#int fa1/2
Switch6500(config-if)#ip nat outside
Question 3)
Overloading with PAT
Switch3650(config)#access-list 1 permit 192.168.1.1 0.0.0.31 (overload the range from 192.168.1.1 to 192.168.1.32 on ip 81.1.1.30 )
Switch3650(config)#ip nat inside source list 1 81.1.1.30 overload
3 REPLIES 3
Re: Port Forwarding and NAT on MX64
Your diagram does not make any sense to me with respect to your questions.  You ask about a second WAN port, but your diagram only has a single cloud.
You go to the Ethernet page on the local status page to change one of the LAN ports into a second WAN port.
https://documentation.meraki.com/zGeneral_Administration/Tools_and_Troubleshooting/Using_the_Cisco_M...
This document covers how to do inbound PAT.
https://documentation.meraki.com/MX/NAT_and_Port_Forwarding/Port_Forwarding_and_NAT_Rules_on_the_MX
Outbound NAT is automatic.  There is nothing to configure.  It uses the IP address configured on the WAN interface that it is going out.
Thx a lot
So Security -> Firewall is all about inbound NATs?
So how should I do the port forwarding for my 2 different webservers, to be accessible from outside on port 80? I have two Public IP addresses on my UPlink interface..
Webserver1 local IP(192.168.1.50)     Webserver2 Local IP(192.168.1.51)
Webserver1 External IP(81.1.1.30)     Webserver2 External IP(81.1.1.31)
no offense taken
question 1 is not about my diagram but where those two uplinks on the device itself are coming from that you explained it.
I can't tell what part of my diagram doesn't make any sense, but if you ask I can explain.
I just need to achieve the same result of these two commands on a GUI
