Policy based routing with different VPN's
wdepauw
Our customer would like to have the following hub and spoke setup
In the spoke MX there will be 2 VPN tunnels
VPN tunnel 1 : Going to the hub ( autovpn with another MX appliance configured as hub).
 => The hub will announce the default route
VPN tunnel 2: Going Zscaler ( non-meraki peer)
=> The goal is that the guest traffic ( LAN subnet1) will be routed to the Zscaler for verification
so I would like to implement a policy that says
=> if coming from LAN subnet1 then push the traffic into VPN tunnel2
I have the impression that you can only do policy-routing based using a specific interface and not a VPN tunnel.
Is the above scenario possible ?
gr
wim
I don't believe that will be possible.
wdepauw
Tx for the feedback , this confirms my investigation
gr
wim
whistleblower
will this (now) be possible with Addressing & VLANs/Source-based default routes?
