Password Recovery
VLG
Password Recovery
Hello Team, is there a password recovery process for the MX-84 Firewall?
Thanks in advance.
NolanHerring
NolanHerring
NolanHerring
To clarify, you can change the password via the General settings on the dashboard.
If the device has a connection to the Internet, it will update.
If you don't, and the serial number doesn't work, then you will most likely have to factory reset the device
Nolan Herring | nolanwifi.com
TwitterLinkedIn
VLG
Thanks a lot, Nolan.
BrechtSchamp
Which password do you mean? The local password? You can check it (and change it) in dashboard in "Network-wide/General".
If you mean your dashboard password, there's a reset procedure for that:
https://account.meraki.com/login/reset_password
