PPOE Connection with Static IP address and VLAN from ISP SIde
HarmeshYadav
Hi ,
Team we have one customer having MX 68 device should be configure
SO customer side they are using broadband
VLAN 100
PPOE Conncetion
And Static IP given by Broad band
we need to configure wan port with correct configuraiton can any one suggest how we should configure wan port in this scenario
We have ealier configure direct and configured static ip its showing bad ip assignment in Meraki device
so we need to configure wan port without error
Regrads,
Harmesh Yadav
5 Replies 5
Proxy
You need to login locally (not via the dashboard) to the MX to set the WAN port as a PPPoE client - enter the username and password provided by the ISP.  https://documentation.meraki.com/zGeneral_Administration/Other_Topics/Support_for_PPPoE_on_Cisco_Mer...
Between the WAN port and the ISP handoff you'll need a VDSL modem (for example Draytek 130) which converts PPPoE to PPPoA.  The MX will then establish its connection as PPPoE client and the static IP will be automatically be picked up - you don't need to (and can't) set that address on the interface.
HarmeshYadav
in Model i have seen - Vlan is configured in PPOE Configuration
So should we require to configure vlan in MX device ?
and other question is like -- What configuration we should do in modem
Modem should be in bridge more or PPOE mode ?
Regards.
Harmesh Yadav
Proxy
Every time I've deployed in this way, the only configuration required in the MX is PPPoE username and password. The modem should be in bridge mode - not PPPoE mode - the MX then becomes the PPPoE client on the network and the modem (in bridge mode) is just a passive device that converts PPPoE to PPPoA.  If you use the Draytek 130 modem, you just un-box it and plug it in.  No config at all required.
HarmeshYadav
Actually i tried multiple times but not succeed
Finally i requested to ISP Person to work jointly
SO He first configured Modem in Bridge mode
And then given static IP to his laptop and then internet starts working. - i tested because i want to confirm before connecting it to meraki device
Then i open setup.meraki.com   Page and did below mention configuration
1. No VLAN Taggig
2. No PPOE Selected -- Selected Direct
3. Configured Static IP
then saved it
Post this configuration it started working
I have two broadband  with same configuration so did same process for both and now in meraki both wan is working as expected and without any error
Thanks for your help guys
Regards,
Harmesh Yadav
TS42
This solved my problem.
The only way we could get the Meraki and the PPOE to play nice was to set the Userid and password for the PPOE, but leave IP address as Dynamic.
