Organizaion wide Group Policies
mikefredrik
Hi
We are testing the org-wide GP that we got enabled in our test enviroment
One thing we noticed is that when you create the rule it's rather straight forward, the next step is then to scope the network you like to assosiate with this GP. Finally you create the GP and attach the scope/rules and then you are able to see the GP attached to the vlan in your scope, works as expected.
Now comes the challenge......
We then added an additional network to the organisation that we would like to use the same GP, be able to better have an overview we like to basically add one more scope with the new network and this new scope then added to the GP.
This is not working, it' an OR statement, you can only select one scope per GP, when the org will grow the list of the scope will be massiv and it will be a risk you miss something when you like to add more vlans to the GP.
The scope in the GP shopuld be AND, so you could have more scopes in a GP
RWelch
Available options:
The following table describes the rules, restrictions, and other settings that can be controlled via group policy on each platform. Only features that are available for the network will be displayed when configuring a group policy.
Creating and Applying Group Policies
RWelch
Troubleshooting Group Policies
RaphaelL
Org-wide GP ? Is that a private beta feature ?
mikefredrik
Yes it’s a private beta right now, the concept and idea is great. As always with beta and early adopters try/test/tweak and give feedback so we all together explore how to adjust if needed based on real life use cases
