We're migrating to the Cisco Community on March 29. The Meraki Community will enter read-only mode starting on March 26.
From the vpn concentrator set up documentation says that when setting the local subnets to be accessed by the remote branches we use CIDR notation
Does this mean we cant use Variable Length Subnet Masking ?
Solved! Go to solution.
this simply means it wants a x.x.x./x format. the mask length can be whatever you need it to be.
you can vlsm in cidr notation
