OSPF check on MX
DiegoAMorelli
OSPF check on MX
Hi all, I need an advise about OSPF on MX, is there a way to check an adjacency has been established properly? a verification method that is not a packet capture. Thanks!
Seshu
Hello @DiegoAMorelli
The EventLogs on the dashboard will have certain OSPF Events that will help with troubleshooting the neighborship status. Here is a document with the details.
For more detailed status, please go ahead and submit a feature request for the same. Let me know if you have any questions.
Regards,
Meraki Team
2 REPLIES 2
Seshu
Regards,
Meraki Team
Thank you @Seshu
