@Indetech you'll have a lot of issues trying to get this working with Meraki, if I were you I'd ask for a single new block and migrate off the existing.
The short explanation is that the MX doesn't support a second IP address / range on the WAN ports.
[Edit] turns out the above is not correct, as long as the ISP can point the secondary range to one of the primary range addresses, that you then assign to the MX interface (or virtual interface). Apologies for the confusion.
