Non Meraki VPN with Sophos XG310
TAxinte
Hello everyone,
I've been trying to make a successfull connection between Meraki MX100 (15.44) and Sophos XG310 (18.5.2 MR-2 build380) for more than 1 week.
I tried to watch some videos, documentations from Cisco or Sophos but nothing works. The logs are pretty much useless and I'd like some professional advice from you guys.
I tried IKEv1 and 2, I tried all the IPsec policies combinations but nothing works.
I was able to see the green light as succesfull connection but I can't ping anything, plus the Sophos from the other side cannot make a connection to my meraki: "parsing IKE message from REMOTE_IP[500] failed"
I want to add that I actually have a meraki to meraki VPN active, does it have anything to do with a new non-vpn connection?
This is my last config that I left with the "green light" on.
2 Replies 2
Inderdeep
@TAxinte : I dont know the exact answer but check this thread if it helps
https://community.meraki.com/t5/Security-SD-WAN/Meraki-MX84-to-Sophos-XG-site-to-site-VPN/m-p/50779
Regards/Inder
www.thenetworkdna.com
Thanks for the reply.  I finally solved the issue after weeks of trying.
Basically in the "Subnets" field I need to specify both local LAN and the remote LAN subnets. That is not documented on meraki. Sad but glad I managed to do it.
