Non-Meraki VPN peer capture traffic
noman
i have weird issue with non Meraki 3rd party VPN tunnel. Tunnel is up if traffic is generated from 3rd side it works end to end but when a server behind my Meraki generate the traffic it doesn’t work, I can see syn packet in the capture on lan interface but I don’t see any hits when I capture traffic on vpn tunnel and my 3rd party also cannot see any traffic on their side. Can someone tell what am I missing .
mwiater
some IPSEC implementations support responder, initiator or both implementations.  It your peer is configured as an initiator only, it won't respond to the MX's attempts to initiate the tunnel.
1 REPLY 1
mwiater
