Does Meraki support DPD (Dead peer detection) ? Cause my branch appliances using DPD in its settings.
Solved! Go to solution.
It's solved already.
Yes, Meraki does have the default setting for DPD.
The timer is set to 10 seconds by default, with 5 retries and a max fail count of 5.
I'm about 75% confident it does. DPD is a negotiated setting.
Where can I find this settings ?
Hi @endrianusgohan ,Can you please share document link also.Thanks
@Foysol ,
The support engineer didn't give me any document link to this configuration, but I can share the screenshot from his solution to my case.
Hopefully that helps.
