Hi
I'm wondering if it's possible to capture traffic for non-Meraki VPN. Would I select the "site-to-site" interface for this or is capturing this traffic not feasible?
Best regards,
Solved! Go to Solution.
If you want to see the traffic un-encrypted, capture it on the LAN interface.
If you want to see the IPSec unencrypted exchange, capture it on the WAN interface.
Directly on the MX as far as I know it is not possible.
Thank you for your response! It's possible that the feature in question is something they'll consider in the future, really like that packet capture feature otherwise
Support already has access to an interface that can do this for what it's worth - I cannot comment on why this hasn't been exposed to customers unfortunately
You forgot the "Make a wish" line. 🙂
Thanks for the reply! Then i can see the traffic i need to be able to troubleshoot this.
