Hello, please help
It is possible this scenario?
A MX64 with two L2L (LAN to LAN) connections each WAN port (no need for VPN tunnels)
Those L2L conectiosn on the WAN ports does not have an internet connection
It is possible to setup a default route to reach internet Trough a LAN interface on the MX64?
Its not necesary to share the internet to other clients by the this MX
- A route to send all the trafic to an internal router with Internet service
I setup this route in an off line system, but not sure if will work, and I have a warning message
Thank you All
Solved! Go to Solution.
Assuming the MX acts as DHCP server, you could setup Option 3, to point your Default Gateway to another host.
Creating an interface on the MX will always make it Default Gateway, unless your instruct your clients otherwise, via. e.g. Option 3.
Right it does not work.
